Serendipite
Dec 05, 2021Follower
Nighthawk M2 disabled
My nighthawk m2 says WIFI Network is disabled but when I try to enable the screen comes up with WIFI Name Disabled and WIFI Password disabled and just continues to try and detect service...I am totall...
IYGEAL
Jan 03, 2022Aspirant
In my case factory reset hasn't helped. Model is AUS version (M21001TAUS), FW is 24.10.17.10. I made a detailed post on the other thread with 95 replies.
JohnPeng
Jan 03, 2022NETGEAR Expert
Can you log in to WebUI and enable ethernet offloading and do a FW upgrade check? There is a newer version available for your device.
FW: 10.19.03.00 and PRI 05.02
Thanks
John
- IYGEALJan 03, 2022Aspirant
JohnPeng wrote:
IYGEAL wrote:
In my case factory reset hasn't helped. Model is AUS version (M21001TAUS), FW is 24.10.17.10. I made a detailed post on the other thread with 95 replies.Can you log in to WebUI and enable ethernet offloading and do a FW upgrade check? There is a newer version available for your device.
Thanks
John
I just connected via USB. Data offloading failed to apply. It stuck at "Applying changes"
Also, Firmware Update is stuck at "Checking"
