addyp95
May 31, 2022Guide
Nighthawk M2 guests are isolated on different bands
Hi there. I've got the Australian version of the M2 (telstra nighthawk m2) with the latest firmware and I've noticed hosts are isolated without any setting to configure this. My use case is that I ha...
Karl-Man2
Nov 09, 2022Tutor
Hey Addyp95,
I have exactly the same issue but across multiple devices and different models.
We have M1, M2 and M6 models and we have confirmed this is an issue on the M2 and the M6 models.
Did you end up finding a fix for this? Did Netgear support reach out?
Thanks.
- addyp95Nov 09, 2022Guide
No Karl-Man2, they never responded or reached out, and I gave up waiting. I've simply stopped using the joke of a device, and wish I had of known before the return period expired.
No idea how to get this to ping the developers or support staff either.
- Karl-Man2Nov 09, 2022Tutor
Ok thanks for letting me know. This is such a weird thing to have inplace an not be able to remove via settings!
I'm going to try and open a support case with Netgear via Telstra and see if i can get an answer as we have multiple devices with this issue. Will let you know how i go.
- JohnPengNov 13, 2022NETGEAR Expert
In our internal testing, this is working as expected. You need to disable firewalls on all the clients so that they are see each other.
Please give it a try and let me know if you still have issues.
Thanks
