kNightRider's avatar
kNightRider
Nighthawk M2 LTE after new firmware problem
Hello, over year it was almost fine with this MR2100. I using it in car, usb powered/from battery. Sometimes, when crossing state borders it need restart, but ok.
After upgrading firmware (from menu) to NTGX24_10.19.03.00 almost every day wifi goes off. Nothing helps, only restart. Can anyone help, how to downgrade to previous version of firmware ? Factory reset will not help. Download page have no fimware to download.
https://www.netgear.com/support/download/?model=MR2100
MR2100 – Nighthawk M2 Mobile Router / MR2100
  • schumaku's avatar
    schumaku
    JohnPeng please join the user discussion - more on the issue, less on the older firmware version to NTGX24_10.17.x - please.
  • JohnPeng's avatar
    JohnPeng
    NETGEAR Expert
    When did you upgrade the device? Could you please help to capture a model.json file and email to me at [email protected]. Please mention your community ID in the email for easy tracking.
    Thanks
    • kNightRider's avatar
      kNightRider
      thanks, sended...
      Today again, factory reset: Modem is in car. When I start car, everything is ok. Modem get energy from USB, activate WIFI and I driving. After 1h30m I stop. Again after 30 minutes I am back, start driving and wifi is offline.
      • JohnPeng's avatar
        JohnPeng
        NETGEAR Expert
        kNightRider wrote:
        thanks, sended...
        Replied your email. Please check the WiFi standby timer setting. This may not be an device issue.
        Thanks
