ed4444
Feb 26, 2021Tutor
Nighthawk M2 M2100 telstra.internet
How do I change the name of the USB tethered router from TPPW4G_2153 to something I prefer?
- Feb 28, 2021
ed4444 wrote:
There seems to be no way to change the router name in Ethernet mode, either in Windows 10 or logged in to Netgear.
That's probably a Windows thing. It names devices like modems and routers and seems to offer little user control.
I am not familiar with the M2 but for other devices you can change the "Device Name" here in the browser graphical user interface:
- Advanced
- Setup
- LAN Setup
Whether or not Windows respects this is another matter. Mine insists on a name that the router had before I set it up to my liking. Seems to be the original default wifi SSID.
michaelkenward
Feb 27, 2021Guru - Experienced User
By name, do you mean the SSID it broadcasts?
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Manage WiFi Settings.
You may have done this already. I can't tell from your message.
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so you might get responses here, but you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
Mobile Routers, Hotspots & Modems
- ed4444Feb 27, 2021Tutor
Thanks! Yes, I mean the SSID that is broadcast.
- michaelkenwardFeb 27, 2021Guru - Experienced User
Read the manual then.
Thanks! My brain was not in gear earlier. Initially I had been using the router in WiFi mode where I had changed the SSID and set a new password. I've now changed to a USB Ethernet connection, so I assume the name of the router "TPPW4G_2153" is not broadcast. I've studied the Manual in depth. There seems to be no way to change the router name in Ethernet mode, either in Windows 10 or logged in to Netgear.
Thanks anyway! Kind regards, Ed
