ed4444
Feb 26, 2021Tutor
Nighthawk M2 M2100 telstra.internet
How do I change the name of the USB tethered router from TPPW4G_2153 to something I prefer?
- Feb 28, 2021
ed4444 wrote:
There seems to be no way to change the router name in Ethernet mode, either in Windows 10 or logged in to Netgear.
That's probably a Windows thing. It names devices like modems and routers and seems to offer little user control.
I am not familiar with the M2 but for other devices you can change the "Device Name" here in the browser graphical user interface:
- Advanced
- Setup
- LAN Setup
Whether or not Windows respects this is another matter. Mine insists on a name that the router had before I set it up to my liking. Seems to be the original default wifi SSID.
ed4444
Feb 27, 2021Tutor
Thanks! Yes, I mean the SSID that is broadcast.
michaelkenward
Feb 27, 2021Guru - Experienced User
Read the manual then.
- ed4444Feb 27, 2021Tutor
Thanks! My brain was not in gear earlier. Initially I had been using the router in WiFi mode where I had changed the SSID and set a new password. I've now changed to a USB Ethernet connection, so I assume the name of the router "TPPW4G_2153" is not broadcast. I've studied the Manual in depth. There seems to be no way to change the router name in Ethernet mode, either in Windows 10 or logged in to Netgear.
Thanks anyway! Kind regards, Ed
- michaelkenwardFeb 28, 2021Guru - Experienced User
- Advanced
- Setup
- LAN Setup
- ed4444Feb 28, 2021Tutor
G'day Michael,
Thanks again for your prompt and detailed reply. It seems your right: I've tried every which way, and there seems to be no way to change the device name. I'll talk to the service provider (Telstra, Australia) shortly, but I'll bet they say it's a Windows or Netgear problem.
Sincere thanks for taking the the time to help.
Kind regards
Ed (PhD in Engineering and Applied Science, with 49 years experience in Computer Science, retired Assoc. Prof. Univ. of Calgary)
