Fionagrace
May 11, 2024Follower
Nighthawk M2 Manager - cruise ship connection
Hi I have this device which I use extensively in the UK and abroad for WiFi then only use one roaming package across all our mobile devices. I’m going on a cruise for the first time in August a...
May 13, 2024Guru - Experienced User
100/day/device?! Wow thats a touch rediculous. You could pay for a month of starlink service based off just the daily rate from 1 device.
The M2 does have wifi offloading (I'd disable its cellular connection so it doesn't default back to it).
Would it work? Depends on the cruise ship as if they're raking in that much per device/day, they're going to be more proactive in monitoring the devices connected. You'd be better to see if they have a forum and what users have used before for their service. Because at that rate, I guarantee that someone else has tried what you're trying or using a travel router with WISP function.
