Nibin94's avatar
Nibin94
Follower
Sep 07, 2020
NightHawk M2 MR2100 - Ethernetport issue
Hello Support,
I have connected MR2100 ethernet port to cisco switch. Router Ethernetport start working only if we touches the screen( press power button or wake the screen) of MR2100.
Request you to revert with fix.
Thanks 🙏🏻
1 Reply
  • michaelkenward's avatar
    michaelkenward
    You have posted your message in the section of this community given over to General WiFi Routers (Non-Nighthawk). (This is easily done, given Netgear's impenetrable community structure.)
    You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
    Mobile Routers, Hotspots & Modems
    I have asked the Netgear moderator to move your message.
