ccall48
Apr 07, 2019Tutor
Nighthawk M2 MR2100 (Advanced Settings Missing)
How do I access the advanced functions within the new M2 MR2100 device. The standard login does not give me access to setup 'advanced' options as described in the manual such as port forwarding etc. ...
bruceyboy1
Apr 12, 2019Initiate
Hi there can anyone including netgear tell me if the MR2100 has port forwding capabilities. If it does no seema to know how to access it??
Cheers Bruce
- ccall48Apr 12, 2019TutorI’m also still waiting.
Contacted support and that didn’t help either.
It’s a great device but without basic functionality control it’s just a paper weight for me.- a12b4c3Apr 15, 2019Aspirant
It will be released in an upcoming firmware update - there were some issues with it previously.
- Blanca_OApr 17, 2019NETGEAR Employee Retired
Hi All,
This has been brought up already to engineers. This will be fixed on the next firmware release.
Blanca
Community Team
- ccall48Apr 22, 2019Tutor
Hi Blanca,
Any idea when this new firmware will be available???
My product support will have ran out by the time this one problem has been recified - And I am still to get a reponse from my ticket reply a few weeks back. Hopeless so far.
Devices are also blocked from talking to each other between network types which is a PITA, and no way to override at the moment either.
