OmarAlmajdi
Jun 12, 2019Follower
Nighthawk M2 MR2100 Port forward help
Hello, Can someone please help me with port forwarding my Router to host a server. I recently bought this device and have no idea how to port forward it. Thanks for reading.
a12b4c3
Jun 14, 2019Aspirant
You cant yet. A new firmware will be out soon which enables the feature. It was removed soon after release after they discovered it broken....
- BourkieJun 20, 2019Aspirant
I have just update the the new firmware after the long re-assurance that the port forwarding would be enabled and there is no change to the menu.
What is going on! This has been assured to me by both Netgear and Telstra and was sold to me as a solution back in April for its Port Forwarding abilities....
- Blanca_OJun 24, 2019NETGEAR Employee Retired
Hi Bourkie
May we please have the firmware version? Kindly PM me the device IMEI and PRI or you can provide a screenshot of the About tab page.
Blanca
Community Team- DrEvilJimJun 27, 2019Aspirant
Hi Blanca, do you have any update to this issue regarding port forwarding function for M2, and the new firmware upgrade that is supposed to resolve this issue.
Regards, jim
