OmarAlmajdi
Jun 12, 2019Follower
Nighthawk M2 MR2100 Port forward help
Hello, Can someone please help me with port forwarding my Router to host a server. I recently bought this device and have no idea how to port forward it. Thanks for reading.
Bourkie
Jun 20, 2019Aspirant
I have just update the the new firmware after the long re-assurance that the port forwarding would be enabled and there is no change to the menu.
What is going on! This has been assured to me by both Netgear and Telstra and was sold to me as a solution back in April for its Port Forwarding abilities....
Blanca_O
Jun 24, 2019NETGEAR Employee Retired
Hi Bourkie
May we please have the firmware version? Kindly PM me the device IMEI and PRI or you can provide a screenshot of the About tab page.
Blanca
Community Team
- DrEvilJimJun 27, 2019Aspirant
Hi Blanca, do you have any update to this issue regarding port forwarding function for M2, and the new firmware upgrade that is supposed to resolve this issue.
Regards, jim
- ArodiDJun 28, 2019NETGEAR Expert
Hi DrEvilJim ,
The latest FW 10.13.05.00 does not have port forwarding feature enabled. Port forwarding will be enabled in a future MR but no ETA at this stage which I not what you want to hear. I will update this post once it becomes available.
Arodi
Community Team
- BourkieJun 29, 2019Aspirant
Thank you for the straight answer. Unfortunately I have been told otherwise since late April and was not able to provide the webservices for my customer as informed by Telstra and Netgear. The difficult part is now discussing with Telstra why we need to get a credit for the M2 as we have been forced to purchase a second solution incorperating the Huawai B618 to have successful port forwarding. The manual and sales literature for Telstra states the M2 has this feature, but clearly dosent, and is therefor advertising features it dosen't have.
The M2 was very fast and quite easy to operate, and having the battery was a bonus for any power interuptions we may have had. As far as how difficult it has been to get a straight answer is now what Netgear need to address.
Thank you for being honest with the functionality.
