pez_'s avatar
pez_
Nighthawk M2 MR2100 port forwarding
Does port forwarding work on this device? I've enabled it and put rules in, but it's not working.   Firmware version NTGX24_10.17.10.00   regards andrew
  • pez_'s avatar
    Sep 20, 2021
    OK i sorted it out. Turns out Telstra (ISP) needed to put a code on the mobile service "GPTEXB3" and then I had to change the apn to telstra.extranet
    https://whirlpool.net.au/wiki/mobiles_apn
    ddg to the rescue.
