Söldier's avatar
Söldier
Nighthawk M2 MR2100 speed reduction
Hello, after using the M2 for a few days, it appears that the speed is significantly reduced. At the original set up i get speeds of 100MBps+. Then after a few days use (ethernet out to wifi route...
