Thanathat
Jul 20, 2024Aspirant
Nighthawk M2 (MR2100) still show Mobile Broadband Disconnected.
I use Netgear Nighthawk M2 (MR2100) but the cellular is still disconnected. I got into the web UI interface to check cellular status, but it is still searching. I have already done a factory reset a...
Jeroenuttwello
Oct 19, 2024Aspirant
I also have the problem with the Nighthawk M2 (MR2100) abroad after May 2024.
Don't know if it has been an update or what, but the led keeps on blinking red and the "Mobile broadband disconnected" is staring in your face.
It does find a network and connects to it, but then the Mobile broadband disconnected message comes, the led becomes red and you have no internet. Any device can connect to the router (wifi), but no internet.
Hopefully anyone found a solution to this problem, because the router is not useable any more and we were so pleased with it in May 2024 when I bought it for a trip in the UK (a month).
Please any one???
Jeroenuttwello
Hi Everyone,
Just found 2 useful links which solved the problem.
The best one:
https://community.kpn.com/mobiel-15/problemen-data-roaming-netgear-nighthawk-m2-4g-router-597480
it is in Dutch, but it has to do with the APN settings of your provider when they are set to fastinternet (4G/5G) then you have to set it back to internet (which means allowing slower internet) - save and it works like a charm.
The other link is a youtub, which removes the slack:
https://www.youtube.com/watch?v=5CmIk1Z8W70
Happy traveling with this router. Back in business.
Jeroen
#NighthawkM2 #MR2100
- ThanathatOct 21, 2024Aspirant
Thanks for your advice. I've already done both solutions but it still doesn't work.
