HornyTaurney
Mar 30, 2022Follower
NightHawk M2 No Data or Wifi
hi community i have issues i have a nighthawk m2 telstra branded. it just stopped allowing wifi and mobile data after i reset it one day, once in maybe 30 boots it will work and if i dont turn it off...
Transfluxor
Apr 04, 2022Apprentice
Does the computer see the USB or Ethernet connection of the router?
I had a similar case - at first the router stopped connecting to the cellular network, after a reboot, Wi-Fi also stopped working. I did a factory reset after which the wired interfaces also stopped working, but the menu still worked, after the second factory reset the router stopped loading. I don't know exactly what your case is but it looks like the router will die soon.
I have already seen several such cases on this forum and it seems that the M2 model is very unreliable. The worst thing is that access to the firmware was closed. Only a service center can try to help. Despite the fact that it would be possible to reflash the router yourself, because even if it does not boot, you can switch it to download mode to reflash it yourself.
I absolutely do not understand Netgear's firmware policy - after all, phone manufacturers freely post firmware, even though the OTA update also works.
Rhysb33
Aug 23, 2022Aspirant
Wondering if you had any luck with this? it seems I have exactly the same problem! Unsure what to do about it. I did manage to get the 4g to work through telstra by entering the APN data. However, it only seems to work every 20 or so boots. Also, wifi is disabled and I've tried all avenues - USB, Ethernet, via screen to enable and it just doesn't come on. There is no "Red Cross" or anything like that. Yes I've gone through the tethering settings and of course done a factory reset about 100 times. Does anyone have a fix? it's only 2 years old.
