JeffWard
Aug 28, 2019Aspirant
Nighthawk M2 offloading issue
M2 offloads to a Samsung Note8 phone hotspot perfectly. Refuses to connect to a Apple iPhone 8 hotspot. The iPhone can be 'seen' by the M2, prompts for the password and adds it to list of preferred...
Blanca_O
Sep 17, 2019NETGEAR Employee Retired
Please check whether the subnet of the WiFi that you tried to offload the WiFi to is 192.168.1.x. If so, please change either the subnet of the WiFi router / hotspot or M2 to something other hand 192.168.1.x (e.g. change one of them to 192.168.2.x) and see if it works.
Blanca
Community Team
- JeffWardOct 07, 2019Aspirant
Thanks Blanca
Understand what you recommend but I run my own local IP addresses on the router not in the 192.168......... range
I'll continue to hunt for a solution
cheers
