Neildeb68's avatar
Neildeb68
Follower
Apr 29, 2021
Nighthawk M2 password disable
Can i disable the password protection on the new M2?
  • Hi Neildeb68,
    Welcome to NETGEAR Community!
    You can configure the WiFi Profile (name, security and password). Here's how:
    1. From a computer that is connected to your network, launch a web browser.
    2. Enter http://m.home or http://192.168.1.1.
    3. Enter the administrator login password.
    4. Select SETTINGS > Setup > Wireless.
    5. Change the settings as needed.
    6. Click the Apply button
    Blanca
    Community Team
1 Reply
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi Neildeb68,
    Blanca
    Community Team
