drego85
Jul 19, 2024Guide
Nighthawk M2 Router - Issues with Intra-Network Data Transfer Speeds
Hello everyone, I've encountered some significant issues with the Nighthawk M2 router regarding the speed of data transfer between devices connected to the same WiFi network. Please note that these ...
drego85
Jul 19, 2024Guide
Hello everyone,
I've encountered some significant issues with the Nighthawk M2 router regarding the speed of data transfer between devices connected to the same WiFi network. Please note that these issues do not affect internet browsing speeds, which are functioning perfectly.
Problem Description
After conducting several tests, I've observed the following:
- When the WiFi profile is set to "Dual-Band WiFi", two computers connected to the same network can exchange data at speeds of 10-18 Mb/s, regardless of whether they connect via the 2.4 GHz or 5 GHz band.
- When the WiFi profile is set to either "2.4 GHz Only" or "5 GHz Only", the data transfer speed between two computers drops drastically to about 0.1 Mb/s, with numerous data losses.
Testing and Results
To support this, I've conducted tests using the iperf3 software, both between two MacBook Pros and between a MacBook Pro and a Raspberry Pi. These tests indicate that the issue persists across different devices.
Dual-Band WiFi
[ 5] local 192.168.1.65 port 5201 connected to 192.168.1.72 port 49200
[ ID] Interval Transfer Bitrate
[ 5] 0.00-1.01 sec 1.12 MBytes 9.39 Mbits/sec
[ 5] 1.01-2.00 sec 1.75 MBytes 14.8 Mbits/sec
[ 5] 2.00-3.00 sec 1.75 MBytes 14.6 Mbits/sec
[ 5] 3.00-4.01 sec 1.50 MBytes 12.5 Mbits/sec
[ 5] 4.01-5.01 sec 1.62 MBytes 13.6 Mbits/sec
[ 5] 5.01-6.00 sec 1.50 MBytes 12.6 Mbits/sec
[ 5] 6.00-7.00 sec 1.50 MBytes 12.6 Mbits/sec
[ 5] 7.00-8.00 sec 1.62 MBytes 13.6 Mbits/sec
[ 5] 8.00-9.00 sec 1.62 MBytes 13.6 Mbits/sec
[ 5] 9.00-10.00 sec 1.50 MBytes 12.6 Mbits/sec
[ 5] 10.00-11.00 sec 1.75 MBytes 14.7 Mbits/sec
[ 5] 11.00-12.00 sec 1.75 MBytes 14.6 Mbits/sec
[ 5] 12.00-13.00 sec 1.50 MBytes 12.6 Mbits/sec
[ 5] 13.00-14.01 sec 1.50 MBytes 12.5 Mbits/sec
[ 5] 14.01-15.00 sec 1.62 MBytes 13.6 Mbits/sec
[ 5] 15.00-16.00 sec 1.62 MBytes 13.7 Mbits/sec
[ 5] 16.00-17.00 sec 256 KBytes 2.09 Mbits/sec
[ 5] 17.00-18.00 sec 2.25 MBytes 18.9 Mbits/sec
[ 5] 18.00-19.00 sec 1.75 MBytes 14.7 Mbits/sec
[ 5] 19.00-20.00 sec 1.75 MBytes 14.7 Mbits/sec
[ 5] 20.00-20.51 sec 896 KBytes 14.4 Mbits/sec
[ 5] 0.00-20.51 sec 32.1 MBytes 13.1 Mbits/sec
2.4GHz Only
[ 5] local 192.168.1.65 port 5201 connected to 192.168.1.72 port 49207
[ 5] 0.00-1.00 sec 0.00 Bytes 0.00 bits/sec
[ 5] 1.00-2.01 sec 0.00 Bytes 0.00 bits/sec
[ 5] 2.01-3.00 sec 0.00 Bytes 0.00 bits/sec
[ 5] 3.00-4.00 sec 128 KBytes 1.05 Mbits/sec
[ 5] 4.00-5.00 sec 0.00 Bytes 0.00 bits/sec
[ 5] 5.00-6.01 sec 0.00 Bytes 0.00 bits/sec
[ 5] 6.01-7.00 sec 128 KBytes 1.05 Mbits/sec
[ 5] 7.00-8.00 sec 0.00 Bytes 0.00 bits/sec
[ 5] 8.00-9.00 sec 0.00 Bytes 0.00 bits/sec
[ 5] 9.00-10.00 sec 0.00 Bytes 0.00 bits/sec
[ 5] 10.00-11.00 sec 0.00 Bytes 0.00 bits/sec
[ 5] 11.00-12.00 sec 128 KBytes 1.05 Mbits/sec
[ 5] 12.00-13.00 sec 0.00 Bytes 0.00 bits/sec
[ 5] 13.00-14.01 sec 0.00 Bytes 0.00 bits/sec
[ 5] 14.01-15.00 sec 0.00 Bytes 0.00 bits/sec
[ 5] 15.00-16.00 sec 128 KBytes 1.05 Mbits/sec
[ 5] 16.00-17.00 sec 0.00 Bytes 0.00 bits/sec
[ 5] 17.00-18.00 sec 0.00 Bytes 0.00 bits/sec
[ 5] 18.00-19.00 sec 128 KBytes 1.05 Mbits/sec
[ 5] 19.00-20.00 sec 0.00 Bytes 0.00 bits/sec
[ 5] 0.00-20.01 sec 640 KBytes 262 Kbits/sec
5GHz Only
[ 5] local 192.168.1.65 port 5201 connected to 192.168.1.72 port 49192
[ 5] 0.00-1.01 sec 0.00 Bytes 0.00 bits/sec
[ 5] 1.01-2.00 sec 0.00 Bytes 0.00 bits/sec
[ 5] 2.00-3.01 sec 0.00 Bytes 0.00 bits/sec
[ 5] 3.01-4.00 sec 0.00 Bytes 0.00 bits/sec
[ 5] 5.00-6.00 sec 0.00 Bytes 0.00 bits/sec
[ 5] 6.00-7.01 sec 0.00 Bytes 0.00 bits/sec
[ 5] 7.01-8.00 sec 0.00 Bytes 0.00 bits/sec
[ 5] 8.00-9.00 sec 128 KBytes 1.05 Mbits/sec
[ 5] 11.00-12.01 sec 0.00 Bytes 0.00 bits/sec
[ 5] 12.01-13.00 sec 0.00 Bytes 0.00 bits/sec
[ 5] 13.00-14.00 sec 0.00 Bytes 0.00 bits/sec
[ 5] 14.00-15.00 sec 0.00 Bytes 0.00 bits/sec
[ 5] 15.00-16.00 sec 0.00 Bytes 0.00 bits/sec
[ 5] 16.00-17.01 sec 0.00 Bytes 0.00 bits/sec
[ 5] 17.01-18.00 sec 128 KBytes 1.05 Mbits/sec
[ 5] 18.00-19.00 sec 0.00 Bytes 0.00 bits/sec
[ 5] 0.00-20.03 sec 256 KBytes 105 Kbits/sec
Additional Observations
- I have reset the router multiple times, but this has not resolved the issue.
- Furthermore, when one device is connected to the 2.4 GHz network and another to the 5 GHz network, they cannot communicate with each other at all. TCP data transfers are blocked by the router, and only ICMP traffic (e.g., ping) is allowed.
Impact
To facilitate data exchange between two computers using the Netgear M2, it is necessary to keep the "Dual-Band WiFi" option enabled. This results in higher power consumption and shorter battery life, which is not ideal for a device that should efficiently manage client communications.
I hope this problem can be addressed in a future firmware update, as it significantly impacts the router's performance in enabling client-to-client communication.
Thank you for your attention to this matter.
Andrea
- drego85Jul 19, 2024Guide
Forgive the double post, it was an error during the editing process of the first post. Can you please delete the second message but also fix the incorrect display of the first one? Unfortunately, I cannot edit them.
Thanks
