Powerbreed
Sep 19, 2020Follower
Nighthawk M2 Screen won't turn on.
I have i Nighthawk M2 that seems to be working fine but the screen won't turn. I normally just check the screen to see how much data we have left for the month but it no longer displays the screen. ...
Nickam
Sep 22, 2020Initiate
I have the same issue. It actually takes a long time to get a response. Sometimes i am just so annoyed and i simply remove the battery and restart it again. But i guess it hurts the device. Anyone know how to fix it?
- Blanca_OSep 24, 2020NETGEAR Employee Retired
Hi Powerbreed and Nickam
Welcome to NETGEAR Community!
May we please know the device SKU (e.g. MR2100-xxxx)? This can be checked on the box of the product or on the barcode label.
What is the firmware version?
Kindly access router settings page, select Settings > Advanced Settings > Device and provide the following:
- Screen Brightness:
- Screen Lock (is it On or Off)
- Time Out (number of minutes)
- Set WiFi Info on Home (On or Off)
Blanca
Community Team
