Powerbreed
Sep 19, 2020Follower
Nighthawk M2 Screen won't turn on.
I have i Nighthawk M2 that seems to be working fine but the screen won't turn. I normally just check the screen to see how much data we have left for the month but it no longer displays the screen. ...
SharkM2
Nov 01, 2020Aspirant
Yes, have the same problem.
Modem works but screen doesn't work.
Anyone have a solution?
- Rygar707Nov 02, 2020InitiateI have the same problem. Unit working but can’t get screen to wake up. Anyone have a fix for this?
- Blanca_ONov 18, 2020NETGEAR Employee Retired
Hi, All,
We are looking into the issue. May we request for the following information:
- Device SKU (e.g. MR2100-xxxx)
- Firmware version
- ISP
Blanca
Community Team- Blanca_ONov 22, 2020NETGEAR Employee Retired
Hi Powerbreed Nickam SharkM2 Rygar707
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Blanca
Community Team- Trish_960Nov 24, 2020Initiate
I have the same issue. Screen won't display (although it doesn't always do this). Still connected to the internet. Blue light flashing. The only way to get the screen to display is to take out the battery.
Has this been resolved?
- Whitey_2021Mar 02, 2021Initiate
Hi there,
I'm having this same issue and it's really annoying! Are these units not supposed to be left on all the time? Mine is and I'm having to reboot it more and more.
Firmware version NTGX24_10.17.10.00
SKU MR2100-1TLAUS
ISP Telstra
We bought this unit in September 2020 so didn't anticipate it playing up this soon so any help would be appreciated.
Thanks in advance :o)
- ArodiDMar 03, 2021NETGEAR Expert
Hi All,
We are looking into this issue. Can you please PM your contact details so that we can work with you to find out the root cause?
Arodi
