Powerbreed
Sep 19, 2020Follower
Nighthawk M2 Screen won't turn on.
I have i Nighthawk M2 that seems to be working fine but the screen won't turn. I normally just check the screen to see how much data we have left for the month but it no longer displays the screen. ...
Bellwood
Jan 06, 2021Guide
I'm also experiencing the same thing - the modem has been on continuously for over 2 months, and now the screen is black and doesn't re-appear on pressing the power button (which is blinking blue) or the home button. However it is working perfectly as a modem. I have not yet taken the battery out because, well, it is working, so why risk losing my internet Also, my admin options do not include a "screen off" function, only a brightness control.
Has a solution been provided by Netgear?
Here are the details:
Model: MR 2100
Firmware: NTGX24_10.17.03.00
Modem Version: SDX24_10.25.00.01
GUI Version: MR2100-1TLAUS_04.02.151.00
PRI Version: 03.12
Firmware Build Date 2020/01/09
Thanks
Phil
