gardyanofgalaxy
Jan 30, 2023Initiate
Nighthawk m2 sim card not installed
Hello, Hello, I have the following problem, my router does not recognize the SIM card (Nighthawk M2) I wanted to reinstall the firmware, but I can't find it on the netgear website. And I can't get ...
Jan 30, 2023Guru - Experienced User
Did you contact your sim card supplier to see if your sim is appropriate for the device?
And that you have the proper APN settings setup?
gardyanofgalaxy
Thanks for the answer.
I know that overnight it will no longer work. I use Vodafone. However, it doesn't work with any SIM card. Is there a way to update the firmware. It doesn't work without the internet. or do you have a backup file for me?
