Vandercoon's avatar
Vandercoon
Follower
Mar 30, 2020
Nighthawk M2 Telstra Xbox connection
I have the Nighthawk M2 router, on my xbox it will connect to the wirless, but the I cant login to Xbox Live or download games etc, if i connect with ethernet cable, I can the connect to xbox live and download, etc, but I get Double NAT problem.
Id prefer to connect wireless if theres a solution for that, but if I need to connect wired then how do I set up the router so I dont get double NAT??
Thanks in advance!
