Rishard's avatar
Rishard
Nighthawk M2 :Use without battery
M2 router is always stationary in home. Manual recommends using without battery. My question is, on removal of battery and connection to the adapter how should I store the battery apart from the obvious, eg, away from sun and damp, should the battery be kept partially charged(intermittent charging) to prolong its life or just left to run flat?
1 Reply
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi Rishard
    Welcome to NETGEAR Community!
    This link may help you out MR2100 User Manual [page 30 - 32]. You'll see information for:
    • Battery Tips
    • General Battery Safety
    • Appropriate Batteries and Chargers
    • Battery Disposal
    Blanca
    Community Team
