Deaso
Jun 04, 2019Aspirant
Nighthawk M2
Issue: the Nighthawk M2 keeps freezing, the blue light on the unit is permanently on, to fix I disconnect and the re connect Please advise what can I do to solve the problem permanently Mark Deas...
MikeMac-Au
Jun 07, 2019Aspirant
Me too. Nine days in and I have had to unplug to get the Nighthawk back up again more than 15 times. I have tried with and without the battery installed - makes no difference. We only have six devices connected. Telstra support told me to do a full re-set - problem is still there. Other posts identify this as a known problem. I really need a solution - now! Some posts suggest Telstra may just replace the box - but do I need an authorisation from Netgear?
Cheers
One Cranky Aussie
JSchnee21
Jun 07, 2019Virtuoso
This seems to happen with every new model. As if the firmware coding process starts over from scratch with each new model / revision.
