Hugo-C
Oct 07, 2019Aspirant
Nighthawk M2
Hello, I am looking for help re using my MR2100 without a battery. Page 26 of the User Guide says..." if you connect ....to a power adapter that supports Quick Charge 2.0 or 3.0,you can remove the b...
n3t
Oct 09, 2019Apprentice
I live somewhere else in the world and don't know this specific adapter, but here is how you should be able to find out yourself:
A normal "legacy" USB power supply only provides 5V, while Quick Charge allows for higher voltages of 9V and beyond. This is what the M2 wants.
Each and every power adapter should have its specs printed on it somewhere — input and output voltages, currents, wattage — so you'd just need to have a close look. If 5V is all that is mentioned, you should get yourself another adapter which supports Quick Charge. If it says 9V, or if it specifies is a range of e.g. 5V – 12V, you got an adapter which supports some sort of fast charging, with Quick Charge being the safest bet unless some other fast charging method is explicitly mentioned.
Hugo-C
Oct 11, 2019Aspirant
I appreciate that advice; 9v charging gets a mention on the unit;so QuickCharge appears to be supported.
thanks H
