InfoMedix
Aug 02, 2020Aspirant
Nighthawk M2
Hi Guys, We have an SG-5100 Netgate Security Gateway (with pfSense) configured as a firewall, LAN or WAN router in our office network. The gateway is by default connected to the internet via Fibr...
- Aug 10, 2020
Probably best start afresh.
michaelkenward
Aug 03, 2020Guru - Experienced User
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's impenetrable community structure.)
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
Mobile Routers, Hotspots & Modems
InfoMedix
Aug 09, 2020Aspirant
Hi michaelkenward,
Thank you for your comments.
Should I re create this and start a new discussion, or has this been moved to the right place?
Thanks.
- michaelkenwardAug 10, 2020Guru - Experienced User
- InfoMedixAug 10, 2020Aspirant
Thanks, will do.
