Stingraye
Aug 09, 2020Aspirant
Nighthawk M2
Hello community is there any way to improve recpetion in a weak signal area ? antenna.
michaelkenward
Aug 09, 2020Guru - Experienced User
Are you asking about the M2 or the AC2100 in your footer?
If the former you might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
Mobile Routers, Hotspots & Modems
Stingraye
Sorry my mistake I did not scroll all the way down.
Ray
