Sarathlalkk
Mar 13, 2021Aspirant
Nighthawk m2
How I connect all mobiles. I can’t connect. Can’t see WiFi to Samsung huawei phones
Sarathlalkk
I can’t connect to all mobiles. Not showing WiFi name why help me pls. How to connect my huawei phone to net gear m2 router.
michaelkenward
Mar 14, 2021Guru - Experienced User
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so you might get responses here, but you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
Mobile Routers, Hotspots & Modems
I will ask the Netgear moderator to move your message.
You could also try this:
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
You may have done this already. I can't tell from your message.
