Rogwhale
Aug 10, 2024Aspirant
Nighthawk M2
Can I install a vpn on the M2?
- Aug 10, 2024
I don't think it has that capability to "install" it to.
If you're traveling that much, I'd check into something like gl.iNet's offerings.
You could even go M2-->gl.iNet--->devices (m2 in passthrough mode)
Rogwhale
I am looking to purchase a mobile router for when I am travelling but I want to use a vpn on it. The M2 is an expensive mobile router but I have Orbi mesh systems and I like their support. I just need to know if I can install a VPN on it as I go to Turkey regularly and they block lots of sites.
Aug 10, 2024Guru - Experienced User
- RogwhaleAug 10, 2024Aspirant
Thank you. I already use the Gl.i as a static router at my property in Turkey. I think their mobile one would also work better than the M2.
I appreciate the response.
Rog
