Rogwhale's avatar
Rogwhale
Nighthawk M2
Can I install a vpn on the M2?
  • plemans's avatar
    Aug 10, 2024
    I don't think it has that capability to "install" it to.
    If you're traveling that much, I'd check into something like gl.iNet's offerings.
    You could even go M2-->gl.iNet--->devices (m2 in passthrough mode)
