leanorth
Jun 13, 2021Aspirant
Nighthawk M2100 - wifi disabled
Hi My M2 has been working fine for a fair time and has just this week lost wifi. Status is showing as connected but Wifi Network shows as Network Disabled. I've tried a factory reset and all of ...
Blanca_O
Jun 13, 2021NETGEAR Employee Retired
Hi leanorth
Welcome to NETGEAR Community!
May we please know the device SKU (e.g. MR2100-1TLAUS) and firmware version?
Have you tried to access the Web UI and enable WiFi? If so, what happen?
Kindly check if you have set WiFi Standby to Disabled.
Blanca
Community Team
Lippy3
Oct 17, 2021Aspirant
Hello:
After a "pin" reset, the message "Wifi network disabled" appears and does not
go away even after accessing the router on the web.
On the web, going to Setting\Setup\Wi Fi profiles, the button for "Turn on Wifi" is always enabled, and
goes back to that situation, no matter how many times I choose/enable either "Dual Band" or "2.4 only" or "5 only".
I hit apply, and then reboot the router, either power the router or via web.
Wifi standby is disabled.
Thanks, Jack
