Thosmas
May 19, 2022Aspirant
Nighthawk M2100
I have the above device which won’t start up, initially it flashes blue gets to 2 dots on the screen then flashes red every 5 seconds! it won’t go any further! any help please!
Transfluxor
May 23, 2022Apprentice
How to do a reset if the router does not boot? It doesn't matter if it has a SIM in it or not, whether it has a battery or not, it just won't boot. Instead of a bunch of useless questions, it would be better to post the firmware, the router is switched to bootloader mode.
Thosmas
May 24, 2022Aspirant
Hi
thx for response
i can’t get firmware if it doesn’t boot
how do I get out of boot loader mode?
- TransfluxorMay 24, 2022Apprentice
Hello, I replied to the previous post.
You do not have a boot mode, when there are two dots on the screen and the red LED blinks - in 99% of cases this means that the firmware of the router is damaged or it is malfunctioning. To check, remove not only the battery but also the SIM card, reboot - if the router does not boot, then there is a problem in the firmware or a malfunction. If you have a certified Netgear service nearby, then you are in luck and it is better to go to them.
