zombee81
Apr 07, 2025Aspirant
Nighthawk M3 and Quest 3 stuttering
The purpose: I want to connect my ASUS ROG Ally to my Quest 3 via the NightHawk M3 (MH3150) to play PC SteamVR games and have large screen experience watching videos while in hospital. The proble...
Apr 07, 2025Guru - Experienced User
Probably because you're on a mobile hotspot. They can have variable latency which impacts your game play big time.
You might check as most hospitals have a "guest network" option for visitors/patients.
zombee81
The hospital hotspot is not good and expensive, also not too safe. The hotspot is like £5 a day, whereas a unlimited data sim is £20 a month.
If that's true about the variable latency, which it looks like it is, then this NightHawk M3 is useless to me. I have tried reducing the bit rate and even down at 4Mbps and it still happens.
- plemansApr 08, 2025Guru - Experienced User
thats the problem with cellular connections, sadly.
otherwise 5g home internet would be booming but the latency causes issues for some tasks. Gaming, latency is key
