Davitzen
Apr 15, 2025Aspirant
Nighthawk M3 Ethernet adapter
Hi, which usb-c ethernet adapter is compatible with such router? I tried an Belkin and an Realtek adapter with no success. May I miss something? Do I have to configure adapter in ui? Best re...
DJLutz
Jun 04, 2025Initiate
I can confirm that Nighthawk M3 MH3150 can work with an USB-C to Ethernet dongle.
It is also announced in Netgear page (Nighthawk® USB-C to Ethernet Adapter):
https://www.downloads.netgear.com/files/GDC/USB2ETH/USB2ETH_TS.pdf
By the way i has been "sold-out" on any e-shop.
When I first got the M3, in the last window/screen it mentioned the option of using an usb-c to ethernet dongle, once firmware was upgraded it did not show that message anymore.
I've been trying many regular 1Gbps dongles, and almost fail, but could get it working with a 2,5Gbps bought on amazon:
Vonxite 2.5G Adaptador USB-C Ethernet+PD100W
It required some setup tweaking on the Router but finally worked.
- turboliftJun 06, 2025Aspirant
I am getting a IP (192.168.1.0/24) and gateway/DNS 192.168.1.1 from the router via LAN Adapter ... But I couldn't access the Internet ... What setup are you using
