IR99
May 20, 2026Initiate
Nighthawk M3 MH3150 and Ethernet Adapter - USB-C input does not charge battery
I have a Nighthawk M3 MH3150 and a Netgear Ethernet adapter. (The M3 has no ethernet port, just a USB-C one, so needs the adapter for ethernet). The adapter has one 'in' port USB-C to connect to...
schumaku
May 21, 2026Guru - Experienced User
Using the original Netgear power supply delivered with your Netgear M3?
IR99 wrote:Netgear Ethernet adapter
The "original" Netgear https://www.netgear.com/mobile-wifi/hotspots/usb2eth/ adapter?
