helvetica's avatar
helvetica
Nighthawk M5 - 2.4Ghz / 5Ghz /or Dual Band option
Hi all, forgive my inexperience with this forum and the way it is meant to work, my first forum, if memory serves right. I have entered the world of mobile routers and now have a Nighthawk M5 mobile...
  • Razor512's avatar
    Razor512
    Oct 04, 2021
    In looking more at your unit, the primary reason is due to the battery. It uses dual band by default, but if all of your devices can use a specific band, you can disable one of the WiFi radios to save power.
    For example, if you will be within range of the 5GHz radio and all of your devices support that band, then disabling 2.4GHz radio will save extend the battery life of the unit.
