Chaotiqq
Jan 08, 2022Aspirant
Nighthawk M5 - Phones get disconnected non-stop
Hi, Any Andoird Phone connected to the WiFi is beeing disconnected non-stop. Yes, I did try a Factory Reset. Yes, I have the latest firmware (at least, it is what the unit claims!) -> NTGX55_12...
Chaotiqq
Jan 19, 2022Aspirant
You can't seriously be suggesting this. It like; every time you enter our garage, remove the engine from you vehicle.
nielsvds
Jan 19, 2022Luminary
You even confirmed when disabling your data connection that you got a stable connection with a very short reconnection time.
You are correct, that the phone will not disconnect if I do disable the data connection. It Reconencts more or less immedatly and it shows full strength.
That is exact the same thing when you disable the option to automatically switch from Wi-Fi to your data connection when the signal is weak. In that case you don't need to disable completely data usage.You should also give Netgear as much information as possible which Android version installed,which security patches installed.
