Mindmaster
Sep 21, 2021Tutor
Nighthawk m5 auto Power ON
Hallo, schaltet sich der Nighthawk M5 automatisch ein, sobald er Spannung via USB-C bekommt?
Mindmaster
Sep 21, 2021Tutor
English:
Does the router automatic power up when a power adapter is connected?
Sep 21, 2021Guru - Experienced User
Review the user manual for this information...
Good Luck.
- MindmasterSep 21, 2021Tutor
did it.
Nothing in the manual.
- FURRYe38Sep 21, 2021Guru - Experienced User
Hopefully someone in the mobile routers forum will know.
