rremus
Feb 26, 2022Follower
Nighthawk M5 Dual-Wifi Options
Hi, i use different Names and Passwords for 2,4 GHz, 5 GHz and Guest-Wifi. Sometimes i change from Dual to only 5GHz, but if i change back to Dual all my Names and Passwords are reset? Do you...
Feb 26, 2022Guru - Experienced User
it helps if you post in the proper forums.
https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/bd-p/aircard
and a single post is enough. You dont' have to post several times.
any time you're changing from single wifi names (mesh) to seperate, you need to change it in the settings.
