rolkergiv
Sep 26, 2025Aspirant
Nighthawk M5 Ethernet port / data offloading
There's so little documentation about this that I don't can't figure out the best way to phrase my question.
If you plug the M5 / MR5200 into a wired switch with it's own Internet access, will the M5 act as an access point?
If so... What happens if you wire two M5s together? Could one act as the Internet gateway, and the other as an AP?
If you are asking whether the MR5200 has an AP mode, then the the answer is no. It only functions as a mobile router.
- rolkergivAspirant
Then what does the Offload Data function actually do?
Thx for following up, your "access point" vocabulary confused me some.
Per the manual:
- https://www.downloads.netgear.com/files/GDC/MR5100/MR5100_MR5200_UM_EN.pdf
The mobile router can use a wired Internet connection with automatic failover support
so that you can connect the mobile router to an existing DSL, cable, or fiber-optic
modem. If the wired Internet connection goes down, the mobile router can automatically
and seamlessly switch overto the backup Internet connection overthe mobile broadband
network for continuous connectivity.
Always-on WiFi will route all traffic over the Ethernet WAN. If the Ethernet connection
fails, the device automatically switches to LTENote that a modem (not a switch or router) is being connected to the M5. The M5 is always acting as the router - the route it uses for internet traffic is what is changing. This is not quite the same as an AP (which performs no routing functions).
I don't know exactly what would happen if you connected the LAN port to another router that had its own set of clients (either directly or via a switch). But I doubt it would work properly.
