FDV
Sep 24, 2024Aspirant
Nighthawk m5 ((MR5100) Wi-Fi Disabling
Hello.
In my Nighthawk M5 (MR5100) Wi-Fi Sleep Mode is Disabled.
But if any devices are not connected to the access point via Wi-Fi, then after a while Wi-Fi still turns off.
And a red cross appears on the Wi-Fi icon on the LCD screen.
And the Wi-Fi doesn't work until I press the button on the hotspot, and then press the Wi-Fi icon and back button a few times
Have you ever had this problem?
Best regards, Dmitriy
Do you have it set on performance mode?
- FDVAspirantPerformance mode?
Hmmmm.
And how?
Over WEB-UI, or in mobile app?Not 100%. I have the MR6150 so a generation newer and its through the device menu.
