ladog86
Nov 03, 2021Tutor
Nighthawk M5 (MR5200) - IP réservée
Bonjour, est-ce que l'un d'entre vous saurait s'il est possible de "réserver" une adresse IP pour un appareil ? Je voudrais faire en sorte qu'il fournisse du DHCP mais que mon Mac reçoive toujours l...
- Nov 03, 2021
Netgear has set up a community forum specifically for the Mobile Router products. Most of the people who watch that forum are more likely to have experience with mobile routers and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/bd-p/aircard
Thank you
Luisa525
Nov 03, 2021Aspirant
The M5 is locked to the Telstra network and requires a nano SIM with a Telstra data plan. Naturally when you're in range of the Telstra 5G network it will create a faster connection but it can also connect to 4G and still deliver decent speeds.
