PoyntingVector
Nov 08, 2021Aspirant
Nighthawk M5 (MR5200) IPv6 WAN support
Hi Community, Somehow this router type is not listed in the model section (MR5200). Anyway, I purchased it ~10 days ago for use in a remote flat instead of DSL internet connection. After having se...
- Nov 19, 2021
Could you please check your APN setting to make sure the IP Type is set to IPv4v6. The APN used may be automatically set to IPv4 only.
Thanks
JohnPeng
Nov 19, 2021NETGEAR Expert
Thanks
PoyntingVector
Nov 29, 2021Aspirant
Thanks John,
I found the location of this setting and changed it to IPv4v6. Now I have IPv6 :-)
