kenshin305
Sep 19, 2021Tutor
Nighthawk M5 MR5200 Only 4G+ NOT 5G on AT&T
Hello, I recently purchased the MR5200 here in America. I'm with AT&T and can only get it to connect to 4G+ when adding the following APN settings: APN Name: ATT Broadband APN: phone PDP: I...
supper-hero
Sep 20, 2021Tutor
Also having the same issue, but unable to connect to anything except the 3G network on T-Mobile in a confirmed 5G coverage zone near DC. I have contacted T-Mobile and they confirmed the IMEI number is marked as "compatible" with their network, and they have created a support ticket for it. If I try to connect to even the "LTE All" band, it searches forever, same with "LTE and 5GNR". Enabling "Data Roaming" and restarting has no effect.
- kenshin305Sep 20, 2021Tutor
Interesting you're having the same problem even though T-Mobile says your IMEI number is compatible.
I'm wondering if my device might be band locked from AT&T's 5G network. Not sure why since Netgear advertises it as an unlocked 5G device that works best on AT&T and T-Mobile.
Hopefully someone can help us soon.
- supper-heroSep 20, 2021Tutor
Also, for clarity, when I try to select "Manual" for the "Network Selection Mode", I am unable to find any carrier at all when selecting either the "LTE All" or "LTE and NR5G" bands (but it works fine on "WCDMA All" for me). Hoping that T-Mobile engineers will be able to clarify this for me in the next few days and if so will post on here.
- supper-heroSep 29, 2021Tutor
Hello again!
So I have bad news and good news:
- The device I purchased (from Canada) claims to support at least the B5 4G frequency band as per the telnet interface. This is reported in the user manual (https://www.downloads.netgear.com/files/GDC/MR5100/MR5100_MR5200_UM_EN.pdf) and on the knowledge base article on supported bands (https://kb.netgear.com/000062411/What-cellular-bands-does-my-Nighthawk-5G-Mobile-Hotspot-Pro-support?language=en_US). T-Mobile uses at least this B5 frequency for 4G (https://www.t-mobile.com/support/coverage/t-mobile-network); however, I was unable to get this device to ever connect to the 4G or 5G bands.
- I purchased another US device from the netgear site at https://www.netgear.com/home/mobile-wifi/hotspots/mr5200/, and this one immediately worked with both 4G and 5G!
So it seems the marketing page for the US device (https://www.netgear.com/home/mobile-wifi/hotspots/mr5200/) *is* actually up to date on supported frequency bands, and that the user manual and knowledge base article on supported frequencies are incorrect. In feedback re my call with netgear just now I asked for the user manual and knowledge base article to please be edited with an up-to-date listing of which frequencies are supported by the MR5200 device, and whether the supported frequencies differ across region of origin or manufacturing date (not sure which is to blame here, but the knowledge base article is a full year out of date).
This works out fine for me because I am able to return my initially-purchased (and pretty expensive) netgear device to amazon canada, but I really hope this information is updated soon so further US customers aren't stuck with an expensive brick before buying the US version.
