TmacTradingLtd
Apr 16, 2023Apprentice
Nighthawk M5 (MR5200) Uplink speed starts Fast then drops to 2Mbps
I am getting frustrated now, because I have now taken out an EE contract to use since I have 5G in my area with them and not with three... I have noticed that yes the device starts fine 60-108Mbps...
TmacTradingLtd
I suspect what is happening is the Cell(s) the router is connected to are getting saturated and the router is not actively checking the surrounding cells to see if there is more bandwidth available and therefor not switching. Instead what I have to do is either turn the data off and on, or reboot the router. This is unacceptable.
JohnPeng
Apr 16, 2023NETGEAR Expert
Could you please help to capture a model.json file and send PM to me?
- Logon to the webui (http://192.168.1.1 ) as an administrator
- Navigate to URL http://192.168.1.1/model.json via the same browser window
- Capture the results (by selecting all + copy) and send it back
Thanks
John
- JohnPengApr 17, 2023NETGEAR Expert
Could you please set the device to LTE ALL in Band Region to see whether the UL drop issue goes away?
Thanks
John- TmacTradingLtdApr 17, 2023Apprentice
Thanks.
I have just tried this now and same thing is happening on LTE All bands.- JohnPengApr 17, 2023NETGEAR Expert
Thanks for the quick test. We released a new update for the device recently. Could you please try upgrade to it and test again.
After you upgrade, please do a factory reset and see whether the issue still happens.
If this is still reproducible, we need to capture some logs to further checking.
Thanks
John
