droinwork
Mar 25, 2022Tutor
Nighthawk M5 (MR5200) wifi connection to local router
Hi, for the internet connection I use a Nighthawk M5 (MR5200) which is very good, but I need to connect it to the wan port to the router of the local network via a wifi connection, I was wondering if...
Mar 25, 2022Guru - Experienced User
Your statement was a little confusing.
You're trying to connect the MR5200 to another router so the MR5200 is supplying the 2nd route with internet connection?
or you're wanting to connect a router that has internet already to the MR5200 so the MR5200 has failover capability?
You also might get better help from the mobile router forum for those devices.
https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/bd-p/aircard
