sutleasti
Feb 15, 2023Follower
Nighthawk M5 questions:
Hey guys, I have a couple of questions regarding the M5 which I hope someone can help answer. To give you an idea of what I’m trying to achieve I owner a camper van that I built out and am working o...
Feb 15, 2023Guru - Experienced User
The M5 doesn't have an extender or wisp mode function.
You'd need that for minimum for the park you're at to connect to and rebroadcast your internet connection.
A option for you?
Pick up a cheap travel router (netgear hasn't made on in years).
I picked up a cheap Gl.inet travel router for this specific thing.
You can set them both with the same ssid.
When you're in an area needing the mobile router, you simply leave the M5 turned on and use its wireless.
Once you're in an area needing wisp mode (for campsites needing login credentials) you turn off the m5 and use the travel router.
And in your home you use its repeater mode.
You're caught a little bit because each setup needs different connections.
Campsites tend to need wisp mode because they have login credentials.
Your home needs repeater/extender mode to connect to the current network.
And traveling you need the M5 mobile part.
The travel router i have, you can set with a mobile sim to supply it over usb or a wan port but you can switch it to extender/wisp mode while setup in that mode. So again, you're a little caught for those.
That'd be the cheapest option for you but takes a bit of work.
JohnPeng
Feb 15, 2023NETGEAR Expert
M5 supports WiFi offloading. It will suit your needs.
When you are at home, enable WiFi offloading to connect M5 to your home router. Then all your clients will get the data from your home network via M5.
When you on the road, M5 will automatically switch to use Cellular data and all your clients will get data from M5's cellular connection.
When you come back home, M5 will automatically switch back to use your home network since WiFi offloading is enabled.
Thanks
John
- plemansFeb 15, 2023Guru - Experienced User
JohnPeng That'll work for at home but in an RV park needing wisp mode?
Does the M5 support that option?
I wasn't aware that it does but I don't have one so can't say 100%.
- JohnPengFeb 15, 2023NETGEAR Expert
In RV part, M5 will just use cellular connection. If the RV part provides WiFi, user can also offload the data to RV park's WiFi to save cellular data.
M5 can remember the previous connected WiFi network. When it detects the WiFi is available, it will automatically switch to it.
Thanks
John
