sutleasti
Feb 15, 2023Follower
Nighthawk M5 questions:
Hey guys, I have a couple of questions regarding the M5 which I hope someone can help answer. To give you an idea of what I’m trying to achieve I owner a camper van that I built out and am working o...
Feb 15, 2023Guru - Experienced User
JohnPeng That'll work for at home but in an RV park needing wisp mode?
Does the M5 support that option?
I wasn't aware that it does but I don't have one so can't say 100%.
JohnPeng
Feb 15, 2023NETGEAR Expert
In RV part, M5 will just use cellular connection. If the RV part provides WiFi, user can also offload the data to RV park's WiFi to save cellular data.
M5 can remember the previous connected WiFi network. When it detects the WiFi is available, it will automatically switch to it.
Thanks
John
