tpepper
Jun 11, 2024Follower
Nighthawk M6 - wanting to run without the battery.
Purchased a Nighhawk mobile router - Model MR6110. Have been travelling for 12 months and it has been plugged to power pretty much all the time which has I think ruined the battery. Have ordered a ne...
Jun 11, 2024Guru - Experienced User
As long as it has enough output, most USB chargers should work. I'd try a higher powered one and a good cable. I've used that exact model on USB power alone and it worked fine
