Jackrobbo
Oct 08, 2024Aspirant
Nighthawk M6 5G router drops connection every night around midnight
Hi All, Basically the problem as described above, really struggling feel like I've tried everything. So strange that every night on the dot it conks out - says it has connection but there’s nothing...
rcpax
Oct 12, 2024Luminary
Can you specify what exact MRXXXX model you have, What firmware version, and what network, and whether you have IP Passthrough enabled of not. Also, what is your average device temp when network is on full load?
- JackrobboOct 17, 2024AspirantHi rcpax and thanks for the reply.
So model is: MR6150
Firmware: NTGX56_12.01.54.00
IP passthrough is off.
Not sure how to find temp info but it runs warm to the touch.
Many thanks!
